NI TestStand
TestStand Top Level Vi
I'm trying to create a Top-Level Vi that shows the user the sequence that is being executed and also any Vi's that are used for test steps.
I want it to look something like this:
I have 2 issues around this:
  1. Whats the best way of going about displaying each test step in the "Sub Panel" window? All steps that require user intervention use LabView, any steps that don't use LabView are doing a simple check or action.
  2. Currently, I am simply using the "User Interface" example to display the sequence, I've literally copied this straight out of the example. It works, but when I try to load a Vi, it fails, stating that it's run into an unknown exception.
Still pretty new to both Labview and TestStand! It's worth noting though that if this sequence is run from TestStand, it all works fine.
(2,559 Views)
(2,529 Views)
