06-06-2006 01:44 PM
06-07-2006 11:32 AM
Mrbean,
It is possible to have three separate sequence view windows, each showing a different column. Attached at the end, find a zip of the three files that I had to change to get this to work.
The steps to follow are:
1) Resize and copy the sequence view control so that you have three of them.
2) Right click each of them, and go down to SequenceView>>Properties
3) Under the columns tab, choose which columns you would like displayed, and enter the width you would like.
4) Add the new SequenceView Controls to the bundle that goes to the ConfigSeqFileViewMgr VI.
5) Update that VI to accept the new bundle, add then add two new invoke nodes to register the new SequenceView Controls to the SequenceFile Manager
6) Open the Full OI – Resize Controls VI, and remove the width property from the SequenceView Control Reference (third one down) to make sure that the original control does not resize at runtime.
Hope this helps!
Josh W
Applications Engineering
06-08-2006 12:28 PM
06-08-2006 12:52 PM
06-08-2006 01:16 PM
06-08-2006 01:44 PM
06-08-2006 02:02 PM
06-08-2006 03:07 PM
06-09-2006 01:29 PM
I've been experimenting a bit just to try and learn, and I now have the Top-Level VI (attached) a little messed up.
1) I can't seem to select/edit the box at the bottom (I put a little label on it "this box --->"). Any idea what the purpose of this box is?
2) Now, when I run the app, my SequenceFile tab starts in the middle of the screen, and the rest is off-screen. I'm sure this has something to do with me putting the SequenceFiles lisbox on the SequenceFile Tab sheet. Any suggestions to fix this?
06-13-2006 11:51 AM
