NI TestStand
TestStand Users Don't Show in LabVIEW UI
I've created some TestStand users within Teststand. When I use File > Login within Teststand, they are in the user drop down. But when I use TestStand Simple UI example in LabVIEW, only "administrator" is populated in the user drop down. What's up with that?
(1,583 Views)
Accepted by topic author al_g
I found the problem. I created the users in 64bit TestStand and ran the Simple UI in LabVIEW 32bit. I copied the "Users.ini" from %TestStand64%\Cfg to %TestStand%\Cfg and now it works as expected.
(1,573 Views)
