NI TestStand
TestStand Version Selector - mfc140.dll is missing
Dear TestStand community,
recently I've faced the following problem. I install TestStand 2016 (32 and 64 bits, both) on Windows 7, SP1. Installation goes smooth, but after restart of PC, I get the message that "... mfc140.dll is missing".
When I start TestStand Sequence Editor, then I recevie message "TestStand 2016 (16.0.0.185) must be active version of TestStand to use the Sequence Editor". When I start TS Version Selector, I get message that mfc140.dll is missing.
Reinstall does not help. The situation is similar for 32 and 64 bits versions.
Also, I installed separately (from distribution folder) TS Tool (like repair of the installation). It didn't help.
Could anyone, please, help me with this issue and suggest, what can cause it?
Thanks a lot in advance!
Sincerely, kosist90
Check out new feature of LabVIEW 2017!
(4,923 Views)
Accepted by topic author kosist90
Hi Kosist90,
In doing some research, I found that a similar issue was resolved by downloading the Visual C++ Redistributable for Visual Studio 2015 here:
https://www.microsoft.com/en-us/download/details.aspx?id=48145
This was based on a forum post seen here:
https://social.msdn.microsoft.com/Forums/vstudio/en-US/1e58044d-8917-4a30-bee4-408593d66fc4/how-to-s...
Please let me know if this resolves your issue.
Adam
(4,876 Views)
Amazing, now it's working! Actually I had installed Visual C++ Redistributable for Visual Studio 2015, but it seems that it had some issue - I uninstalled it; installed the one from those links what you've provided, and everything is fine now.
Thanks a lot, Mada_17!
(4,866 Views)
That's great news!  Thanks for letting me know.  Best of luck!
Adam
(4,864 Views)
It might be worth noting that you need to install the version (32bit or 64bit) of .Net corresponding to the version of Teststand you have installed NOT your operating system.
(4,360 Views)
