NI TestStand
TestStand adaptors and Vision Deployment license
I have installed Teststand and LabVIEW in my PC. I have no Vision Development Module in the PC,but using Vision Deployment license and changing TestStand adaptor to “LV RunTime”, is it possible to run the TestStand sequence with LabVIEW Vision VIs ?
(4,586 Views)
From a TestStand perspetive :
TestStand uses the LVRTE (Labview Runtime) to run the VIs in the runtime mode.
So if a VI runs in the Labview runtime then TestStand should be able to run it in RTE (run time) mode.
I am not aware of the Vision module VIs and its licensing requirements.Probably you can check in vision forum.
Hope this helps.
Ravi
(4,531 Views)
As far as I understand, Vision Deployment and Vision Development are the same license, just with different agreement on what you will do with it.
We run Vision with just the deployment license in the scenario you described and it works fine.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,515 Views)
