NI TestStand
TestStand and Labview
Hi all, long time lurker!
I'm creating a teststand application that uses LabVIEW Vi's, currently the LabVIEW Vi's pop up in the center of the screen when the step is called, but I'm wondering if it's possible to have a front panel Vi that displays all steps dynamically in a subpanel or something?
Has anyone got a good place to start with something like this?
Teststand: 2014 or 2017 (Have access to both) LabVIEW: 2015
Thanks 🙂
(1,050 Views)
So you have an requirement where you will have single standalone UI where the Step UI needs to be  displayed  as Sub panel Dynamically based on step execution?
There is no straight forward method to achieve this, can be handled in LabVIEW by just Passing VI Names from Steps.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(1,024 Views)
(1,008 Views)
