NI TestStand
TestStand and adapter java
I would like to know if the adapter java is available for TestStand 4.2 ?
If yes, how to install it ?
Thanks for your help
Patrick
(4,091 Views)
There is no java adapter but you can interface Java with TestStand
With the link below, we can see you are able to call Java step type with Teststand 3.0. So you should be able to to the same with Teststand 4.2.
What is New for TestStand 3.0?
http://digital.ni.com/public.nsf/allkb/557C26504F9290388625734800678D37?OpenDocument
And please refer to this link (there is an exemple in TestStand With Java Step Type)
http://zone.ni.com/reference/en-XX/help/370052H-01/tssuppref/infotopics/java_steps/    (TestStand 4.2)
http://zone.ni.com/reference/en-XX/help/370052K-01/tssuppref/infotopics/java_steps/    (TestStand 12.0)
I hope it helps,
MatthieuR
(4,075 Views)
