NI TestStand
TestStand can add comments for the sequence calls?
I am writting ToolBox (a set of sequences and subsequence which I will using many of the times).
If I call a sub sequence from the ToolBox I want TestStand to add comments automatically for the sequence call.
Could someone help me in knowing where is the option to do so.
Thanks in advance.
Sagar Joshi
(4,116 Views)
Accepted by topic author joshisagarr
I guess the only option is to do so using the ActiveX API.
But I guess, this will take some efforts to do so....
(3,980 Views)
