NI TestStand
TestStand can't find vi
After installing SP1 on LabView 2009 I tried to run a sequence that worked b4 the update from the sequence editor and TS reports it can't find the VI. The VI is where it has always been. I get a runtime error but no option to find the VI. How do I help TS find it? The VI in question is several calls deep.
jvh
(3,172 Views)
Are you using relative paths to specify the VI file?  If so, check your TestStand search directories to make sure they include the location of the VI.
(3,157 Views)
That's a good question, Mark. I inherited this thing and being new at TS and LV I am not aware of how the addressing mode is specified.
Turns out my immediate problem was caused when the .tsw file was modified during a remote login troubleshooting session.
jvh
(3,149 Views)
