NI TestStand
TestStand close notification from a DLL
How can I get a close notification from TestStand to my loaded DLL? I would like to have a message/notification from TestStand that it is in progress of shutdown, before it does FreeLibrary() on my DLL. This is to ensure that I always do a clean exit.
Alternatively; can I have TestStand call a function inside my DLL before doing FreeLibrary?
(3,598 Views)
You can use the dll entry point DLL_PROCESS_DETACH in your DLL which is executed each time teststand unloads your DLL. See also http://msdn2.microsoft.com/en-us/library/ms682583.aspx
In Teststand you can define when your DLL should be unloaded in the Step Properties of your C/C++ Prototype Adapter -> Run Options -> Unload Options. The Dll is also unloaded if Teststand shuts down.
If you use CVI you can insert the code needed with:
Edit->Insert Construct ->DLLMain
This is what you get:
#include <cvirte.h>
int __stdcall DllMain (HINSTANCE hinstDLL, DWORD fdwReason, LPVOID lpvReserved)
 switch (fdwReason)
  case DLL_PROCESS_ATTACH:
   if (InitCVIRTE (hinstDLL, 0, 0) == 0)
   return 0;   /* out of memory */
   break;
  case DLL_PROCESS_DETACH:
//here you can enter your clean up code: FreeLibrary(..)
   CloseCVIRTE ();
   break;
 return 1;
(3,537 Views)
But when I receive the DLL_PROCESS_DETACH is after TestStand has unloaded the DLL file. Thus it does not give me any chance to properly  clean up.
(3,497 Views)
Ok, I see.
Do you know the TestStand API function TS_ExecutionInitTerminationMonitor and TS_GetTerminationMonitorStatus?
You can use these functions in your DLL to find out if a TestStand execution is terminating/terminated.
Hope this helps.
(3,482 Views)
