NI TestStand
TestStand create CSV report
Hi
I am using TestStand 2021, I want to generate results report in CSV format to able open it in Excel sheet, So please if you can help me with some examples.
I found some information says I can do that with create new process model plug-in but there is no any example shows that .
Please help.
The attached files are the example I created to try to generate CSV report file.
(1,652 Views)
I have older version of TS/LV and can't open your attachments but, if you have used the create new process model plug-in, it should open a template sequence and available in the result processing (sample):
If you only want to create a report on end of test, you may add your VI in Model Plugin - End. Will still be based on your requirements but it is not required to use all of the subsequences.
(1,587 Views)
