NI TestStand
TestStand engine installation wizard
if i create a custom installer on my computer and then install the TestStand engine to run sequences on a machine which is sold to a customer, i need to purchase a �basic run-time� licence for TestStand.
My question is now, have i to change the serial number (registration data) of TestStand on the machine or is the licence paper enough.
(3,826 Views)
When you buy a TestStand runtime license, all you get is a piece of paper with a serial number on it. For TestStand 3.0, when you install the runtime engine, it will ask for a serial number. Use the serial number that comes with your new license. The registration process will give you the computer ID of the machine you are installing it on. Then you must register that serial number and computer ID with NI, and you will get an activation code in return. When running the TestStand runtime engine on the new computer, you will be asked for this activation code. Enter it and you can use TestStand runtime without limitation. Without the code, you can run TestStand Evaluation version for 30 days and it will limit your running time to 10 minutes per session.
- tbob
Inventor of the WORM Global
(3,826 Views)
Thank you for your answer.
What do we have to do if we use TestStand Version 2.0.1f?
(3,826 Views)
For Teststand 2.0 just enter the license you get with the run-time license. You don't need an activation code for teststand 2.0 (SRQ:195304).
(3,826 Views)
