NI TestStand
TestStand file format
Hi all,
I'd like to know dynamicaly/programmaticaly which teststand file is in Ascii file format or in TestStand file format.
in fact, if ascii file I use winmerge to compare. If teststand file format, I use TS File Diff tool.
I see that all TestStand files start with "TSOF1" string. Is it a good way for that?
Thanks for your help
(1,484 Views)
Accepted by topic author maxmont
The API to get the format is Engine.GetFileInformation(path).FileWritingFormat.
If you don't want to use the API, you could check for "TOF1".  That isn't guaranteed to never change, but I'm pretty sure there are no current plans to change it.
(1,459 Views)
Thanks for your response.
I use "TOF1" header checking and it's working well.
(1,431 Views)
