NI TestStand
TestStand hangs on step sequence
I am having issues with a CVI test sequence hanging in TestStand 2010 & 2012.  Currently, the only way to resolve this is to exit/close TestStand.  Following this we must replace the entire project with a backup project.  This only occurs about once a day or so with the sequence running continuously.  It will hang on the first or second step in the sequence, usually the first step.  Has anyone experienced this phenomenon?
(3,905 Views)
This forum is the Discussion Forum Feedback which is for messages about the forums themselves.
You want NI TestStand forum.
(3,900 Views)
Is there a memory leak which adds on with each run ( since you are running continously).
After hang is it not enough if you restart TS and rerun the sequence?Do you need to copy the sequence files again with related files like CVI dll?
(3,849 Views)
