NI TestStand
TestStand operator interface
I want to write a TestStand operator interface by LabVIEW, but it is too difficult to complete it by myself. So, I want a demo as a reference.
Message 1 of 9
(7,869 Views)
The source code for the TestStand User Interface (or Operator interface) is supplied with the TestStand installer.
Refer ( This is for TestStand 14 )
C:\Users\Public\Documents\National Instruments\TestStand 2014 (32-bit)\UserInterfaces\Full-Featured\LabVIEW\Source Code
Also look in the following folder for a simple Operator interface :
C:\Users\Public\Documents\National Instruments\TestStand 2014 (32-bit)\UserInterfaces\Simple\LabVIEW\Source Code
Use this as a starter.
Hope this helps.
Ravi
Message 2 of 9
(7,866 Views)
Mathis_B created an API located here to help with the creation of Operator Interface in LabVIEW. I haven't personally used it but it might help. I agree that making a Operator Interface is no easy task nor for the faint of heart. I hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 3 of 9
(7,854 Views)
There have been a few examples posted over the last few years that I would refer to:
http://www.ni.com/example/31148/en/
https://forums.ni.com/t5/NI-TestStand/Simpler-Operator-Interface-Example/td-p/3518683
https://forums.ni.com/t5/Example-Code/Dynamic-LabVIEW-Subpanel-in-a-TestStand-User-Interface/ta-p/36...
I'm not sure exactly what you want in your interface but hopefully the included examples along with these will be helpful.
Pulido Technologies LLC
Message 4 of 9
(7,842 Views)
Thanks.
Message 5 of 9
(7,835 Views)
Thanks a lot. Your answer is very helpful.
Message 6 of 9
(7,828 Views)
I have downloaded the demo from http://www.ni.com/example/31148/en/ , and run the SimpleUICode.VI in it. The Function of the VI is realized OK, but it always pops an error box as follows.
Do you have some solutions?
Message 7 of 9
(7,770 Views)
That may not have been the best example to link to.  Here's a fixed version.  This is one of the simplest that I've found and if all you really want is the absolute bare minimum in a UI, this might fit.  In my experience though, it's likely that people may start to ask for a little more functionality and user friendliness.
In case you're curious, I had to fix a bug in the application manager control.  I also changed the Run event functionality so that it uses "TestUUTs" instead of running a selected sequence.
Message 8 of 9
(7,731 Views)
Thank you very much!
Message 9 of 9
(7,685 Views)
