NI TestStand
TestStand password
I am deleloping a test with TestStand 2010. I have protected sequence file changes from test users by setting a password for administrator, which I have now ... forgot (yes, I know, that is stupid!). I thought I had saved it in my password database (keePass2) but obviously I was mistaken.
I thought that by uninstalling TestStand and re-installing it I would have had the chance of resetting the user information, but I was mistaken there too ...
How can I rescue my TestStand development? Should I uninstall all NI s/w development suite?, cleanup the registry?
Any help very appreciated.
Marco
Message 1 of 8
(5,674 Views)
Accepted by topic author mpb
Try renaming the User.ini file in the CFG folder, then launching TestStand SeqEditor. There should be a new User.ini file created with the default settings. ie Administrator without any password.
Regards
Ray Farmer
Message 2 of 8
(5,665 Views)
Thanks very much! That solved th problem.
Regards
Marco
Message 3 of 8
(5,661 Views)
I have a similar issue. I have deleted the user in CFG but after restart back seq editor and trying to skip step its say password protected.
Message 4 of 8
(1,302 Views)
What is the user logged in to TestStand?
Message 5 of 8
(1,298 Views)
user.pngAdmin
Message 6 of 8
(1,293 Views)
Admin is no default account. So ther could be different privileges assigned which could cause this issue
Misread, sorry
Message 7 of 8
(1,286 Views)
Your issue is not rooted in the user privileges but in the fact that somene has locked the SeqeunceFile using a password
Message 8 of 8
(1,283 Views)
