NI TestStand
TestStand pointeur en valeur retournée
Bonjour,
je dois utiliser une fonction dll standard, qui renvoie une chaine de caratctères : Prototype C : char  * version();
Vu qu'il n'y a pas de possibilité de récupérer un pointeur dans une valeur retournée, comment peut-on récupérer la texte dans un appel de fonction TestStand ?
Merci pour votre aide.
Jean-Marie.
JMCe
(4,376 Views)
(same question in english) : Hello,
I have to use a standard dll function , which returns a string pointer : (C prototype: char * version (void));
Given that there is no possibility inTestStand getting back a pointer in a returned value, how can we get back text in such a function call ?
Thank you for your help.
Jean-Marie.
JMCe
(4,371 Views)
TestStand does not currently support string return values because TestStand doesn't know how to deallocate the memory associated with the string. If you must call a function in a standard DLL that returns a string, you have a couple of options. Each of them requires you to write your own DLL.
1. Write a wrapper function in a DLL that calls the string function. Your wrapper DLL must link to the standard DLL. For example,
void VersionWrapper(char returnValue[], int bufferLength)
    char *versionString = version();
    if (versionString != NULL)
        strncpy(returnValue, versionString, bufferLength);
    // You must deallocate versionString here if necessary.
2. Call the string function in TestStand manually specifying the return value as an integer. Write a conversion function in a DLL that converts the integer to a char pointer. For example,
void ConvertIntToString(int returnValueFromTestStand, char returnValue[], int bufferLength)
    const char *returnValueString = (const char *)returnValueFromTestStand;
    if (returnValueString != NULL)
        strncpy(returnValue, returnValueString , bufferLength);
    // You must deallocate returnValueString here if necessary.
Note: If the string function in the standard DLL is exported with a C++ decorated name, the function will not appear in the function list in TestStand and you cannot use option 2.
(4,352 Views)
Accepted by topic author J.M. Cereuil
Hi Erik,
thanks for yor reply. The second option was what i've tried yesterday, (as i don't have the source code for the version function).
here is my c code for a very little dll :
void __declspec(dllexport) GiveMeTheText(long pointeur, char *Texte)
    if (pointeur != 0)
        strcpy (Texte, (char *) pointeur);
as Pointeur is a TestStand value, it's equal to 0 or plus.
Texte is also a TestStand string, then not null.
It is a pity we do not find it in the TestStand AP.
Thanks a lot!
JMCe
(4,330 Views)
