NI TestStand
TestStand says prototype changed
When starting my main sequence TestStand is complaining that a VI's prototype has changed. The file had been opened and saved inadvertently but the comparison tools shows no differences between the archived version and the working version. This vi is touched dozens if not hundreds of times so it will be a major undertaking to stop at each place TS complains and reload the prototype.
Why does TS think the  prototype has changed? Is there an easier way to fix this problem?
jvh
(3,592 Views)
Accepted by topic author jvh75021
Bug in 4.2 and 4.2.1. Use "Tools > Update VI calls" as workaround.
(3,574 Views)
