NI TestStand
TestStand sequence file automatic generation
Is it possible to generate automatically sequence file? I think it's possible but have no reference idea. Look forward to your reply.
Have a good day.
Best Regards,
(4,176 Views)
 Google can help with everything 😃 Check this, for example - https://forums.ni.com/t5/Example-Program-Drafts/Dynamically-Create-a-Sequence-File-with-the-TestStan.... In this example it's done directly in TestStand, but the similar code you can create and call from LabVIEW.
You should use TestStand API; with it you can generate whatever you want...
Sincerely, kosist90.
(4,170 Views)
You can find examples in the TestStand Examples folder, for 2014 version look in \Examples\TestStand API\Building a Sequence Using API.
For earlier versions such 2010 you can find in \Examples\SequenceBuilderTool.
Regards
Ray
(4,147 Views)
Thanks for your reply. I almost confused with full of brain capacities at that time 🙂
I resolved this issue and thanks once agin.
Best Regards,
(4,126 Views)
