NI TestStand
TestStand sequnce is failing even though all (actively result recording) steps are passing
Good morning TestStand experts,
I am facing the situation that I am executing a historically grown sequence, that itself calls a lot of sub-sequences, with each sub-sequnce implementing a lot of steps.
With a new SUT I am seeing the parent sequence failing, even though all sub-sequences and individual steps are passing.
Can someone give me a hint on how to find out, which step is causing the parent sequence to fail? I was thinking that probably there is a step, which has the "Step Failure Causes Sequence Failure" flag set to true in the "Step Settings -> Properties -> Run Options" while it has the "Result Recording Option" set to "Disabled". A first test showed that this is possible, but how would I find out, which step is causing the issue?
Thank you so much in advance
-Michael
(2,018 Views)
Accepted by topic author digisaar
Hi Michael,
Have you tried to enable option "Break on Step Failure" in "Execute" menu?
Mateusz Owczarek
Certified LabVIEW Architect
Certified TestStand Architect
(1,980 Views)
Thank you Matheusz.
(1,967 Views)
You're welcome, glad I could help! 🙂
Mateusz Owczarek
(1,948 Views)
