NI TestStand
TestStand variable of 'restrained' says it is an expected token
I have a variable inside a container called "restrained".  When i use this variable name to call a .NET function, the value box shows in red, and the error i'm getting states it's an Unexpected Token, and that it will cause a runtime error.  However, i am able to run it as it and no run time error occurs.
Still, i was wondering why this happens, it appears that Test Stand is trying to tell the operator that that is a key word or token, but it actually isn't.
~Mark
(2,992 Views)
Can you show us the contents of the edit control window? Maybe copy and paste the expression in here or take a screenshot of the module panel section of the window and attach it to this thread.
-Doug
(2,965 Views)
