NI TestStand
TestStand version selector
I installed TestStand 3.1 on my PC.
But Version Selector show me 2.0.1,
I want to change it to 3.1 but not successful.
Anothing is my LabVIEW7.1's library "\labview7.1\vi.lib\addons\" has no "TestStand" folder.I try to copy this folder from another PC,but when TestStand is starting,the"Teststand" under "\labview7.1\vi.lib\addons\" disappear.
What happende?
*The best Chinese farmer*
(3,836 Views)
It sounds like it hasn't installed properly.
Try doing an un-install, deleting any TestStand 3.1 folders, reboot your system and try the installation again.
Regards
Ray Farmer
Regards
Ray Farmer
(3,833 Views)
Hi Farmer
Thank you very much.
I tried follow your advice,then re-installed TS31,but nothing has changed,
Every time I restart computer system show an error for labview server as attachment,then TestStand Configuration start automatically,but version selector is still like before.
Every time "TestStand" folder under labview's vi.lib>addons is disappear when I start TS3.1.
It seems that TS3.1 deleted the folder?
(3,814 Views)
Are you restarting with administrator rights?
regards
Ray Farmer
Regards
Ray Farmer
(3,806 Views)
Successful!
I have fixed it. I uninstalled TS and then clear all TS information in system register.
Then restarted computer and re-installed, TS now works fine.
The cause maybe old register information for prevenient TS version.
Thanks very much,Ray.
(3,803 Views)
