NI TestStand
TestStand will not let me edit sequence calls
I can't edit the parameters of sequence calls in my files.  Since the problem started I've restarted TestStand, restarted my computer, and installed the latest service pack from NI Update Service.
The problem started while I was diffing two files ... although I don't know if that has anything to do with it.
Has anyone seen this?  If you have suggestions to troubleshoot I'll try them out!
(3,774 Views)
There was a bug related to this:
http://forums.ni.com/t5/NI-TestStand/Unable-to-change-step-settings/m-p/1771360
http://forums.ni.com/t5/NI-TestStand/Copy-Sequence-Call-To-Another-Sequence-File-Causes-Sequence/m-p...
Also, make sure the current user has privileges to edit the file.  Also, make sure the file is not read only.
Other than that I wouldn't know.  Maybe try fixing TestStand?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,767 Views)
