NI TestStand
Testand : Database Options : Schemas for Multilple Numérique Limite Test
I'm looking for a Testand Schemas (Database Options)
which store at each step (MultiNumeric) multi values
on multi lignes on the modele of STEP_NUMERICLIMIT
ex : N mesures -> N NUMERICLIMIT lignes in BDD
(3,273 Views)
I'm not sure I understand what you need. Do you want to take multiple measurements from a step and store them to one record in the database table? If that is the case, you can add as many columns as you need to your table on the Columns/Parameter tab in Database Options.
Matt Pickard
(3,273 Views)
Thank you Matt for your attention
I need to store multiple records for a multiple measurements step
(3,273 Views)
To PMR Christoff -
The default schemas for TestStand 2.x and 3.0 already log generic step result information to the STEP_RESULT table and individual measurement results for the MultiNumeric Limit Test to the MEAS_NUMERICLIMIT table. Can you explain how the default schema is different than what you would like the database logging feature to do?
Scott Richardson
Scott Richardson
https://testeract.com
(3,273 Views)
Thank you for your comment,
it'is for me a new solution for the use of MultipleNumericLimit Test Results
(3,273 Views)
