NI TestStand
Testing if element in array to set numerical limit
I would like to test whether a station global string is a member of a station global string array. If it is, I would like to use a special numerical limit, and if not use the normal limit.
Is there a preferred way to do that? Thanks.
StephenB
(4,337 Views)
Accepted by topic author stephenb2
Well, I learned about conditional statements today. (Great explanation here.) I can put this expression in for the low and high limits.
( Contains( StationGlobals.MyStringArray, searchstring,False)) ? LimitTrue : LimitFalse
 StephenB
(4,326 Views)
