NI TestStand
Testplan freezes after MessagePopup with image
i am using TS2019_f4 and have a problem with the normal "Message Popup" step.
In here i have only text and in the options a jpg that is shown.
When rightclick + run selected step then its working.
When executing the complete sequence then the popup is shown with the image -> i can press OK -> the popup closes -> but TestStand does not continue the testplan....
It stops/freezes with the execution arrow pointing on the message popup step.
But: When i disable the showing of the image then it is working normally.
It looks like there is an interaction with my custom c# steps that are executed before the message popup and are also showing an image in an custom popup.
Here i am using Windows Forms with the zedgraph.dll that shows a trace.
is this a known bug?
Is there a workaround so that i can still uses images in the NI message popup?
Thanks for help
TM
Message 1 of 1
(351 Views)
