NI TestStand
TestsStand Crashes
Hello, I have a sequence that uses a lot of .NET code modules, and sometimes it suddenly crashes. I'm wondering: is it possible that these crashes are due to missing set of object references to nothing?
Thanks in advance.
(1,153 Views)
These issues can be tricky to troubleshoot.  Steps to troubleshoot issues like this:
  1. Repeatability - is the issue repeatable.  In other words can you cause it to crash doing the same thing every time or is it completely random
  2. Isolation - hone in on exactly what is causing the crash.  Remove code that you know isn't contributing.  Create prototype/demo code that could possibly reproduce the issue but with just a couple steps.
  3. Identify - Once you isolate and make the issue repeatable then you can identify what is causing it.  It could be a null reference, it could be a missing dependency that is only seen during a certain condition, it could be an IT update.... who knows?  But until you isolate it and make it repeatable we can't identify it.
Sorry I can't be more helpful but I know nothing about the .NET assemblies you are consuming in your test and I know nothing about your code and how you are calling things.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(1,117 Views)
