NI TestStand
Testsand AssemblyLoadContext and WPF
We are migrating our code from TS2019 to 2025 and .net4.8 to .net8
From what I noticed teststand is using 'TSExecutionAssemblyLoadContext' for all code that user executes in sequence.
We call some WPF forms and those require isCollectible flag to be set to false in order to work properly.
Is there a way to modify this flag for TSExecutionAssemblyLoadContext??
Alternative would be to load all wpf code dynamically like a plugin approach in another context? This will lead to cross context issues when i need to pass some class to my wpf UI in sequence logic?
(417 Views)
Accepted by topic author pawhan11
In the newer version of TestStand where you can use .NET 8, there is a new option to load modules in a context where isCollectible is false. Recommend to use it.
To use the option, do the following:
  • In the step settings pane of .NET adapter, click 'Advanced Settings'.
  • Uncheck the checkbox which mentions 'Allow unload of the assemblies specified in the step'.
-Shashidhar
(387 Views)
Thx, this allowed us to solve the issue!
(374 Views)
There is another issue. We have top level application in labview 2025Q3 that calls Teststand to run sequences. When we start tests from our LabVIEW app the same issue happens. When started directly from teststand all works fine...
Is there some strange interaction between LabVIEW + Teststand + .NET taking place?
(163 Views)
