NI TestStand
Teststand 2010 SP1 Sequence Editor Lauch Error
Hi, everyone.
Today I have installed the Teststand 2010 SP1 eval version on Windows XP but an error pops up when I run the sequence editor, as per shown in the attached screenshot.
Hopefully, someone can help and advise me on this.
Thanks.
Message 1 of 8
(4,528 Views)
Make sure you have Service Pack 3 installed for Windows XP.
Regards
Ray Farmer
Message 2 of 8
(4,519 Views)
thanks.
But my PC is installed with Windows XP SP3.
Message 3 of 8
(4,493 Views)
When you run the TestStand Version Selector, do you get any errors?
Jim
Message 4 of 8
(4,481 Views)
Yes, there is an error.
Please refer to the attached picture.
When I tried to make active of Teststand 2010 SP1, there is also an error.
Message 5 of 8
(4,472 Views)
I've never seen those errors - maybe somebody else has and can give better advice.
I'd try doing a repair operation from 'Add or Remove Programs'.  If that doesn't work then doing an un-install and re-install should fix it.
It does look like the installer couldn't access the registry the first time.  I'd disable virus scan and Microsoft updates before trying a second time and check that the installer is run in an 'Administrator' account.
Jim
Message 6 of 8
(4,431 Views)
Make sure you reboot when it prompts you after the install. I've seen weird stuff like this happen if I try to open TS and I've neglected to reboot the PC after installing.
CTA, CLA, MTFBWY
Message 7 of 8
(4,416 Views)
Hi uoi,
I have created a Knowledge Base article which addresses the issue described in this thread. Hopefully, you have long since found a solution for your issue but I wanted to leave this here for anyone that may run into it in the future.
KyleP
Message 8 of 8
(4,270 Views)
