NI TestStand
Teststand 2019 and "Generate PDF Report" Issue
Howdy all,
I have Teststand 2019 installed on the development workstation and on the test workstation. For this issue, here are the known data:
1. Sequence file used on both workstations - dev and test -- is identical.
2. Configure -> Result Processing -> Report -> Options are identical with the exception of final location (e.g. "$(ClientFileDir)…" vs "F:\\FooData")
Now with these
On the development workstation, I'm able to generate PDF reports (via Configure -> Result Processing -> Report -> Options, checkmark Generate PDF Report). On the test workstation, the same sequence file does not generate PDF reports even when the Generate PDF Report is checked in Config->Result Processing.
Why?
I've already compared the configuration settings for everything - side by side (development workstation is actually a laptop so I could do that with the test workstation which is a desktop) - and all looked the same.  Is there somewhere else that I may have missed checking?
Thanks!
(1,799 Views)
Hello
Copy the contents of the folder "C:\Program Files (x86)\National Instruments\TestStand 2019\Components\Models" from development to test workstation, just to be sure all settings are the same. (rename your test folder so you can go back if something evil happens)
You can also try to create a deployment app, this will ensure all your dev workstation  data and config is the same as test workstation .
(1,699 Views)
A long overdue reply.
Thanks, fcodel111. I'll try what you suggested when I have my time with the test workstation. The deployment app approach sounds more viable and I'll definitely try that angle after trying the copy contents route.
(1,630 Views)
