NI TestStand
Teststand 3.0 Deployment looking for a file(glang.chm) in a wrong path
Hi, Please help
i just try deploy an installer using TestStand 3.0. it can successfully process the workspace file,  But, when the TestStand deployment tool try to build the installer, it keep looking for one of project file(glang.chm) in a wrong path, the error message is following, see the attachment for the screen shot
Error Code:7
Could not process LabVIEW VIs. Fix any broken VIs before rebuilding. LabVIEW error:
C:\MVS 2\data\data\data\glang.chm - source does not exist
i understand that it is looking for glang.chm in "C:\MVS 2\data\data\data\", but in my project, glang.chm actually is under "C:\MVS 2\data\". In order to make it works, i need to create the path "C:\MVS 2\data\data\data\" and copy glang.chm into the path.
My question is: How to change the setting in TestStand deployment tool, so that it would look for glang.chm in corrected path"C:\MVS 2\data\", not in "C:\MVS 2\data\data\data\" ?
Message 1 of 1
(4,311 Views)
