Brian,
I have been able to get IVI-DMM steps to work with TestStand 4.0 before, so we're probably looking at a problem either with your IVI configuration or with how we're using that configuration from TestStand.
and attach your IVI configuration from the computer that is having trouble?
Could you attach a short sequence file that reproduces this behavior? Are you using the same sequence file in TestStand 3.5 and 4.0?
I'm also looking into this on my side to see if I can reproduce it, but with this information I'll have a better chance.
Thanks!
Josh W.
Certified TestStand Architect
Formerly blue
