NI TestStand
Teststand 4.1.1 PAWS Run-Time System ActiveX Server
I downloaded Teststand 4.1.1 for evaluation. However, when I tried to run the example called "Manual Intervention Example.seq" or "ParameterPassingExample.seq" shows an error.
Both sequences indicates "PAWS Run-Time System ActiveX Server not installed."
Error: Error executing substep 'Execute TPS'.
An error occurred calling 'ExecuteTPS' in 'IExecuteTPS' of 'NI ATLAS StepType 1.0'
The TPS Server could not be created. A possible cause is that the PAWS Run-Time System ActiveX Server is not installed. Check your TYX PAWS installation and try again. [Error Code: -2147221164, User-defined error code.]
 Where do I get that installation from?
Why wasn't it installed when I install the evaluation for Teststand 4.1.1?
(3,428 Views)
Try here:
http://www.tyx.com/index.html
regards
Ray Farmer
Regards
Ray Farmer
(3,407 Views)
What I would question is why are you trying to run an example for ATLAS if you don't have ATLAS installed. If you know what ATLAS is, then you should know where to get it. Do you know what ATLAS is?
TestStand does not include any programming languages. You would have to provide LabVIEW, LabWindows/CVI, C++, C#, VB.NET, HTBasic, ATLAS, etc if you want to run an example specific to one of the languages.
(3,401 Views)
