NI TestStand
Teststand API in LABVIEW
Hello Friends,
In the sequence editor , i am able to get the TestStand API  RunState.Step.Module.AsLabVIEWModule.RemoteHost = ""
But i am not able to get the same Teststand API properties in Labview with sequence Context. Herewith in attached the image for your ref.
Anyone knows how i can get the above teststand API in LABVIEW.
Prithivi
(3,826 Views)
Hi Prithivi,
you have to cast the Module Reference to LabVIEWModule Type before you can use it. Following document will be useful to you:
How Can I Programmatically Access Information about a Code Module that a Step Executes (e.g. Name, Path)?
http://digital.ni.com/public.nsf/allkb/ADC6909C20E27D4886256E94005424E3?OpenDocument
Regards
MY
(3,808 Views)
Thanks a lot .
I got the point that i need.Once again thanks for your valuble information
Gopal
(3,787 Views)
And don't forget to close the reference to the Step.Module property, since it is actually a different reference than what the Variant to Data vi outputs.
Jervin Justin
NI TestStand Product Manager
(3,771 Views)
