NI TestStand
Teststand DVR deleted between two executions
Hello
In testStand, we have two LV step with DVR.
  • The first LVstep, DVR is created and use stationglobal to store it
  • The Second LVStep, re use the stationglobal and re use DVR.
If the two step are running in the same execution , all work fine
If the two step are running in two different execution ( step by step) ,  teststand generate a issue that the reference is deleted
Also, we have two behaviours vs TestStant version when  we try to run  in two different execution
  • 2019 no issue
  • 2022 issue
Work with  LV2019
Any idear of this two behaviours vs TS version
TS configuration ?
Thank's for your help
Message 1 of 1
(931 Views)
