NI TestStand
Teststand Datalog File Name Wildcard naming option disappeared
For some strange reason the Wild card Datalog File naming option isn't working anymore, as you can see it used to work on 05/16/2019 but today it isn't working anymore.  Anyone  know where this control gets turned on and off at?  Can alternate Process Models do this?:
(2,412 Views)
I had switched to a Batch Process Model when I noticed it started doing this, but when I switched back to the original normal default process Model the problem didn't go away.  I am still not able to assign UUT # , Time or Date to my Teststand Datalog File.
(2,355 Views)
