NI TestStand
Teststand Deployment Utility - Find origin of dependency
Hi all,
I'm trying to integrate our VIs and sequences (these are a lot) into a build I am creating with the Teststand Deployment Utility.
Some older files I removed as they shouldn't be needed anymore (e.g. in user-created "backup" or "trash" folders), but there seem to be quite some references to these files, as the Deployment Utility tries to locate them.
Now I cannot find the origin of these dependencies as the utility only shows the path to the file it cannot find, but not the origin.
Is there a way to make the utility show which VI or sequence file is referencing the removed files?
Any hint or help appreciated.
Best regards
J. Ludwig
(2,194 Views)
Accepted by topic author J.Ludwig
Hold on - I found it.
The "Additional Details" section can be minimized and looks like this:
When clicking the marked arrow it expands and shows the caller (including path): 
Best regards
J. Ludwig
(2,154 Views)
