NI TestStand
Teststand Development hangs on execution
I'm using Teststand 2014(32-bit). I've been trying to deploy my test system. The Deployment Utility was working fine until recently. Now it opens but doesnt finish loading. I've tried reinstalling it but the probably still persists.
Any ideas on whats going wrong?
(5,793 Views)
@cathalcasey wrote:
[...]Now it opens but doesnt finish loading.[...]
Loading what? Your Build Script? Or is the tool not coming up correctly?
Norbert
Norbert
Expert: Geometry
(5,653 Views)
Norbert
The tool is not coming up correctly. The application opens but I only get a loading cursor so can't click on anything.
(5,644 Views)
You don't open it by opening a Build Script file from Explorer, don't you?
If you do, please try opening the tool from either the Start Menu or from the SeqEdit Tools menu.
Norbert
Norbert
Expert: Geometry
(5,633 Views)
Norbert
I've tried opening from the Start Menu and Tools menu but same result.
(5,631 Views)
You said you tried "reinstallation". Did you refer to a "repair install"?
Also, you can try to run the NI TestStand Version Selector tool and activate your TS installation again.
Another thing is to run a HD check to make sure that there are no faults on your hardware making Windows to stuck during load processes.
Norbert
Norbert
Expert: Geometry
(5,595 Views)
Accepted by topic author cathalcasey
Fixed. I had tried the repair installed option on TestStand and it didnt work but I then used it on the Teststand Run-Time Engine which has fixed the deploymment utility. I think the problem was I accidentally ran an installer for my test system that had the Teststand Run-time Engine included.
Thanks for the help. I really appreciate it.
Cathal
(5,573 Views)
