NI TestStand
Teststand Operator Interface: CommandKind_RunSequences_Set doesnt work with Teststand 2016
Hi all,
i would like to know if someone also experience the same issue:
1. I have created a Teststand OI (based on LabVIEW)
2. I have a Teststand's button on my OI:
   - It shall be able connected to Sequence (index "x") in a Sequence File "dummy.seq".
     Sequence (index "x") does: "Do this"
3. It works with:
   LabVIEW 2012 - Teststand 2012
   LabVIEW 2014 - Teststand 2014
   LabVIEW 2015 - Teststand 2015
   but not with
   LabVIEW 2016 - Teststand 2016
4. Error -17500 occured once i connect button with "CommandKind_RunSequences_set", and set index "x".
   See picture. In this case, my index x = 2
5. Once i removed/disable that function, my operator interface does work, but no extra button shown up as before.
6. I have modified also Simple UI example, by adding that function and i can confirm that it didn't work either.
Can someone please tell me if this is a bug or there is something i am not aware of any Teststand 2016's features?
Rajamodol
(5,159 Views)
Rajamodol,
Yes, this bug was only recently discovered and is being tracked under CAR 643567. The TestStand team is currently investigating a fix for this.
The only workaround I've found is to use a native control for your button instead. Create a callback to handle the button event and use the API spawn a new execution for your specific sequence.
Trent
https://www.linkedin.com/in/trentweaver
(5,141 Views)
Well, i can't imagine how many teststand users, especially GUI developers, will be going to complain as we have to do an extra work for this things..
I can't confirm yet if using native control will work but thanks for your quick reply.
Rajamodol
(5,129 Views)
Accepted by topic author rajamodol
In case it helps, I've attached a simple example. This is a modified shipping example with an event handler for a normal LabVIEW button with the following code:
If you'd rather pick the sequence by index instead of name, you could call GetSequence on the SequenceFile reference
Hope this helps!
Trent
(5,065 Views)
