NI TestStand
Teststand PDF generator does not include images
I have a new issue with reports as I now need to include complex graphs.  My customer likes the PDF version of the XML report that Teststand can generate but this week I tried to add an image of a graph from LabVIEW using the <IMG> tags in ReportText.  the XML view works fine, but the generated PDF shows the ALT text not the image.  Is there any way to make the PDF generator include the image?  The PDF does include the images of teststand generated array data graphs, but in my case i need a coloured bar chart.  Im using TestStand 2019.  Thank you
Message 1 of 1
(1,077 Views)
