NI TestStand
Teststand - References to PropertyObjects were not released properly
 I am getting an error when exiting from Teststand.
"References to PropertyObjects were not released properly."
Error report attached
I've just had Teststand installed on a WIN7 PC and no changes have been made to the configuration. Any help would be appreciated.
(972 Views)
I've never seen where TestStand didn't release a type palette like that.
Did you reboot your machine after installing?  The reason I ask is that because part of the reboot process will go register the activex controls properly.  I'm wondering if something isn't being registered correctly.  You can go run the version selector and get the same behavior.  Ensure that all things are registered properly.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(942 Views)
