NI TestStand
Teststand Report Format/Stylesheet Help
I'm having some trouble modifying the horizontal.xsl stylesheet to achieve the format I want, but as with teststand there's always many different ways to achieve the same thing I thought I'd throw it out there incase im missing the obvious.
The horizontal.xsl stylesheet produces a report which matches the structure of your sequence files. Each time you have a subsequence, the stylesheet "indents" a new table of results for that subsequence. The resulting report is great if you wish to follow the structure of the test. For my application however, I would like a single table of results regardless of how many subsequences the code has. Please see the attached files to get a clearer idea of what I am trying to achieve. The "ReportGenerated.xml" is the output from "Test.seq" using "horizontal.xsl". The "ReportWanted.html" file is a rough example of what I am trying to achieve by creating my own xsl stylesheet.
Ideally, I'm hoping I'm missing a tickbox in teststand options or something entitled "group all results into one table" lol. However, I suspect i'm not so if anybody could offer any ideas on how best to achieve this I would really appreciate it!.
Steve
(4,317 Views)
Find the Attached image of the Horizontal.xls where I have commented the "Indent" so that it will not look like a tree Structure, try it and let me know whether it is working,
This is just an Example, you have to study XSLT and a liitle Javascript before editing the Style Sheet.
To achieve these kind of Table Structure, Fonts etc,. you have to edit the Style Sheet
AshwiN,
(4,311 Views)
Same here, new in Test Stand.
Did you find a way on how to optimize the report like your example "ReportWanted.HTML"?
(3,588 Views)
