NI TestStand
Teststand Report generation doc
Hi Guys,
I'm looking into TestStand reports right now, but I have to admit that I'm a little bit lost...
I would like to get an easy "manual" on how to edit the reports so I can get my own formating in the report...
For example, I would like to present my test results like this
Description of test (name)    ||    Low limit    ||   Measurement    ||     High Limit     ||    Pass/Fail.
This would be the case for every test step.
Also , I would like to have a customized header with a logo, and some additional Information like operator name, SN, etc
A solution I was thinking about was to send all my data back in LabVIEW and generate the report from there, which is quite easy... I found a way to get back part of my data, but unfortunately, the NumericLimitTest steps don' return the Result... (the function I used is on this page http://forums.ni.com/ni/board/message?board.id=330&message.id=1311&requireLogin=False) >> TestStand-Labview-Resultlist.vi is the one I used.
Could you help me on this?
Thanks a lot
Matthieu
(3,316 Views)
Hi Matthieu,
Here is a Developer Zone article that should help get your starting with understanding how report generation works: Report Generation Explained .
See the following knowledge base article for information about logging data of a step: How do I Modify a Step Type to Log Data into a Report?
If you are using an HTML report, please see the following knowledge base article for information about how to customize your header information: Modifying HTML Report Headers to Include Custom Information in TestStand .
This should get you started with reporting in TestStand.  I think that you will find that TestStand is better suited for reporting as you become more familiar with it.
Jessica
Product Support Engineer
(3,271 Views)
