NI TestStand
Teststand Tries To Execute A Step That Is Not In Sequence
I have a problem were teststand is trying to execute a step that is not present in the current test sequence. When i try to run the sequence, its loading modules, after that, it fails. I have tried to unload all modules, but i still have the same problem.
(1,049 Views)
Hi JoeRamos
Depending on how your choose to run a sequence TestStand may run a whole bunch of steps before and after calling your sequence.  Are you selecting Run MainSequence or TestUUTs or Single Pass to start your sequence running?  Do you see any difference in behaviour between you run using Run MainSequence and TestUUTs?
Are you able to provide any detail of the failure you are seeing, a screen capture of the failure/error would be great?
Regards
Steve
(1,023 Views)
