NI TestStand
Teststand Utility Problem Reading Dependencies (-19052)
Hi all,
I am trying to build TestStand deployment using TestStand Deployment Utility.
Before starting the build, i have move the entire folder into a LabVIEW project to ensure there is no missing of dependencies and any other errors.
However, my build is still failed due to certain error which i do not understand.
Can someone please help to take a look on the failure? Thank you.
XJ
(1,284 Views)
Hi all,
The issue has been resolved. The root cause is i missing some MNU files in the instrument library.
XJ
(1,266 Views)
