NI TestStand
Teststand Variable over Network between two Computers
Hello
I have two computers that running Test on Testunits.
One of them also takes over the control of your climate chamber and the reading of the serial numbers.
Now I have to pass these numbers on to the second computer.
The computers are connected to each other via Ethernet.
Is this possible with the board resources from Teststand?
(1,878 Views)
Hi Chris2000
You can transfer files from a development computer to a test station computer by using distribution media, by copying files from a local network, or by using email or FTP, depending on the location of the test station computers and available resources.
For more information, please follow this link.
Regards)
(1,846 Views)
Is it possible to use FTP or Email with only Teststand.
I know i use Shared Variables with Labview but in the current situation i have only Teststand
(1,809 Views)
Hi Chris2000
To my knowledge, yes, you can use FTP file transfer step without using LabVIEW. For email transferring there is no such information about that I have found, and I didn't try that yet. Try to test it in your side by using FTP file transfer step.
Regards)
(1,803 Views)
If you have TestStand on both the machines, you can use Synchronization objects to send the data between machines.
Quote from the following link - "You can also create a Synchronization object on a specific computer by beginning the name of the object with the computer name, such as \computername\syncobjectname, which you can use to access the Synchronization object from any computer on the network. "
Also see - Setting Up TestStand for Accessing Synchronization Objects Remotely - NI
Anand Jain
NI
(1,792 Views)
is there an example for the use.
Because if i try to use it, i get an Syntax error.
(1,755 Views)
More information about how to configure the name - Name - Common Attributes of Synchronization Objects - NI
Anand Jain
NI
(1,741 Views)
