NI TestStand
Teststand add TSUI. Checkbox to the Teststand UI Data TypeDef
I am trying to add a TestStand Checkbox Vi to the Simple UI.
Adding this to the form is no problem. But how do I add  to the UIData Cluster under Visuals Controll?
There is no ActiveX TSUI.ICheckbox to add .... Where do I find it?
(1,653 Views)
Solved ... found it in NI Teststand 2019 UI Controls Version 1.0 ... CheckBox (TSI.ChecBox.1)
(1,634 Views)
After placing an "Automation Refnum" in the "Teststand UI Data" TypeDef, rightclick on the icon an select the the menu "Select ActiveX Class" then "Brows.." and search for the "NI Teststand 20xx UI Controls Version 1.0"  Library .
After this select  the desired object in the field below.
This is how I did it in the TS simple GUI.
(1,617 Views)
