NI TestStand
Teststand & QTP
I use TestStand for creating test sequences. I am just curious to know that, is it possible to run TestStand using QTP scripts. Has someone tried this before? My purpose is to automate test sequence creation using QTP.
(3,420 Views)
TestStand has an extensive ActiveX and/or .NET API.  So if QTP can call through one of those then you should be good.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,417 Views)
Hi AmitShah,
     Were you able to build a TestStand sequence using QTP?
(3,332 Views)
