NI TestStand
Teststand batchReport not appending .html to S/N links
Good day folks,
So, we are running batch process model and get two versions of reports:
- xml reports (need to open in internet explorer or edge)
- html reports (can open in chrome)
now, there are two types of reports for batch process model as you know and for each, there are two types (xml and html) generated:
- batch report
- socket report
When we open the xml batchReport, we see several links of each socket's S/N that, when clicked, would open each S/N's xml test report.
Each xml file, also, opens normally, fine.
Now, here is the problem:
When we open the HTML batchReport and click the same S/N links that should take us to the each socket (S/N) HTML test reports,
it does happen but when the link is inspected, the ".html" is missing from the filename.
separately, each socket's html test report, has the correct extension appended and opens fine.
The above table sn when clicked from xml batch report is fine BUT when clicked from html batch report, it tries to open the xml instead of html.
It seems that the .html batch report does not append the .html to the socket reports' filenames' extensions
I might be doing something wrong... please do let me know 🙂
Thank you!
(886 Views)
Does this behaviour also appear when generating HTML reports only?
which version of TS are you using?
(862 Views)
TestStand 2023 x64 (2022 Q4)
We used to generate only xml reports, when we had 2018 TestStand, installed.
However, when switched to 2023, the html reports, also, got added, without any intervention from us.
And that's when this issue was noticed.
(829 Views)
