NI TestStand
Teststand deployment error -17500
Just wondering if anyone had seen this error before (also attached jpg):-
Starting Log.
Processing Workspace...
Done processing workspace file
Error Code:-17500
Unknown System Error in TestStand - Read Seq Files in Workspace.vi->TestStand - Find Dependent Files.vi->TestStand - Add File and Dependent Files.vi->TestStand - Process Workspace File.vi->TestStand - Update File Info.vi->TestStand - Distribution Wizard GUI.vi->TestStand - Deployment Utility Splash Screen.vi
My build hasn't been changed - I simply got the latest versions of files from sourcsafe and went for a build. I've tried rolling back to previous versions of sequences and vi's but still get the same error. The error isn't particularly specific so I'm not really too sure where to start debugging it - especially when it appears nothing has changed!
Any replies appreciated.
Message Edited by davidpcl on 04-25-2006 05:28 AM
David Clark
CLA | CTA
Genesee Technologies Ltd
Hampshire, England
(3,608 Views)
here is a link with the same symptoms as yourself. Doesn't look like it was resolved but may highlight something for you to check.
http://forums.ni.com/ni/board/message?board.id=330&message.id=9578&query.id=86918#M9578
Regards
Ray Farmer
Regards
Ray Farmer
(3,601 Views)
Hi Ray, Thanks for the link. It's always heartening to know that your not the only one with a certain problem, but it's a bit depressing to see that they have been unable to find an answer to the problem.
I'll try giving NI a shout anyway - hopefully they might have found a solution since that post.
Thanks again
David Clark
CLA | CTA
Hampshire, England
(3,596 Views)
We may have found a cause/solution to the problem. I've added it to the thread that Ray has provided the link to.
David Clark
CLA | CTA
Hampshire, England
(3,594 Views)
